Feiyutech GSC Software debug Problem
FPVOlli
Der mit der Dominator
Hallo Gemeinde,
Wie der Titel schon sagt, seit gestern kann ich mein FY31 nicht mehr proggen weil mir Windows ein Jit debug Problem meldet. Kurioserweise existiert dies Problem unter Vista und Win7.
Genaue Fehlermeldung hier:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Invalid DockState: Content can not be showed as "Unknown" or "Hidden".
at WeifenLuo.WinFormsUI.Docking.DockContentHandler.Show(DockPanel dockPanel, DockState dockState)
at WeifenLuo.WinFormsUI.Docking.DockContent.Show(DockPanel dockPanel, DockState dockState)
at GCS.WinMain.cmdToolStripButton15_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
GCS
Win32 Version:
CodeBase: file:///C:/Program Files (x86)/FeiyuTech/FeiyuTech.exe
Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
GCS.resources
Win32 Version: 2012.04.12.01
CodeBase: file:///C:/Program Files (x86)/FeiyuTech/en-US/GCS.resources.DLL
Assembly Version: 2.5.0.15095
Win32 Version: 2.5.0.0
CodeBase: file:///C:/Program Files (x86)/FeiyuTech/WeifenLuo.WinFormsUI.Docking.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Interop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program Files (x86)/FeiyuTech/Interop.SHDocVw.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Hat jemand von euch ähnlich Probleme oder viellecht sogar ne Lösung???
Die Software ist eine kleine Diva, aber so was hatte ich auch noch nicht. Hast was neu installiert, gelöscht oder der gleichen?
Ich hatte mir neulich auf dem Laptop eine Software zum Aufnehmen installiert, seitdem fährt er nur noch zugeklappt hoch.
Rene
e-Splash
Sorry für das ausgraben..
hab das gleiche Problem unter WIN 8!
Hat jemand eine Lösung? Neu aufsetzten kommt leider nicht in Frage.
