Schaltausgang über den Buzzer Port:
Hab die Betaflight Naze FW mal durchforstet und im Ordner src/main/io die Datei Beeper.c gefunden. Dort habe ich die Beeper Ein/Aus Zeiten so verändert, dass der Buzzer-Ausgang über den Aux-Switch (hoffentlich) dauerhaft einschaltet.
#ifdef BEEPER
/* Beeper Sound Sequences: (Square wave generation)
* Sequence must end with 0xFF or 0xFE. 0xFE repeats the sequence from
* start when 0xFF stops the sound when it's completed.
* "Sound" Sequences are made so that 1st, 3rd, 5th.. are the delays how
* long the beeper is on and 2nd, 4th, 6th.. are the delays how long beeper
* is off. Delays are in milliseconds/10 (i.e., 5 => 50ms).
// short fast beep -> wird für AUX-Switch benutzt, sollte jetzt nicht mehr ausschalten (0 Pause)
static const uint8_t beep_shortBeep[] = {
100, 0, BEEPER_COMMAND_STOP
// arming beep
static const uint8_t beep_armingBeep[] = {
// armed beep (first pause, then short beep)
static const uint8_t beep_armedBeep[] = {
0, 0 BEEPER_COMMAND_STOP
// disarming beeps
static const uint8_t beep_disarmBeep[] = {
// beeps while stick held in disarm position (after pause)
static const uint8_t beep_disarmRepeatBeep[] = {
// Long beep and pause after that
static const uint8_t beep_lowBatteryBeep[] = {
// critical battery beep
static const uint8_t beep_critBatteryBeep[] = {
// transmitter-signal-lost tone
static const uint8_t beep_txLostBeep[] = {
// SOS morse code:
static const uint8_t beep_sos[] = {
// Arming when GPS is fixed
static const uint8_t beep_armedGpsFix[] = {
// Ready beeps. When gps has fix and copter is ready to fly.
static const uint8_t beep_readyBeep[] = {
// 2 fast short beeps
static const uint8_t beep_2shortBeeps[] = {
// 2 longer beeps
static const uint8_t beep_2longerBeeps[] = {
// 3 beeps
static const uint8_t beep_gyroCalibrated[] = {
// array used for variable # of beeps (reporting GPS sat count, etc)
static uint8_t beep_multiBeeps[MAX_MULTI_BEEPS + 2];
Hat zufällig jemand Eclipse installiert und könnte mir eine Hex kompilieren?
Lg
