Hallo zusammen
Würde gerne den SBUSS Kanal meines Empfänger benutzen für meine Multiwii.
Ich habe die Multiwii 2.4
Soviel ich weis habe ich zwei Möglichkeiten entweder den Gaskanal oder die Serial Anschnluss RX1 zu benutzen.
Was muss ich im Sketch anpassen das einer der Möglichkeiten Funktioniert.
**/******** special receiver types ********************/
****/**************************** PPM Sum Reciver ***********************************/
******/* The following lines apply only for specific receiver with only one PPM sum signal, on digital PIN 2
*********Select*the*right*line*depending*on*your*radio*brand.*Feel*free*to*modify*the*order*in*your*PPM*order*is*different**/
******//#define SERIAL_SUM_PPM PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2,AUX3,AUX4,8,9,10,11 //For Graupner/Spektrum
******//#define SERIAL_SUM_PPM ROLL,PITCH,THROTTLE,YAW,AUX1,AUX2,AUX3,AUX4,8,9,10,11 //For Robe/Hitec/Futaba
******//#define SERIAL_SUM_PPM ROLL,PITCH,YAW,THROTTLE,AUX1,AUX2,AUX3,AUX4,8,9,10,11 //For Multiplex
******//#define SERIAL_SUM_PPM PITCH,ROLL,THROTTLE,YAW,AUX1,AUX2,AUX3,AUX4,8,9,10,11 //For some Hitec/Sanwa/Others
******// Uncommenting following line allow to connect PPM_SUM receiver to standard THROTTLE PIN on MEGA boards (eg. A8 in CRIUS AIO)
*****// #define PPM_ON_THROTTLE
****/********************** Spektrum Satellite Reciver *******************************/
******/* The following lines apply only for Spektrum Satellite Receiver
*********Spektrum*Satellites*are*3V*devices.**DO*NOT*connect*to*5V!
*********For*MEGA*boards,*attach*sat*grey*wire*to*RX1,*pin*19.*Sat*black*wire*to*ground.*Sat*orange*wire*to*Mega*board's*3.3V*(or*any*other*3V*to*3.3V*source).
*********For*PROMINI,*attach*sat*grey*to*RX0.**Attach*sat*black*to*ground.**/
******//#define SPEKTRUM 1024
******//#define SPEKTRUM 2048
******//#define RX_SERIAL_PORT 1 // Forced to 0 on Pro Mini and single serial boards; Set to your choice of 0, 1, or 2 on any Mega based board (defaults to 1 on Mega).
******// Defines that allow a "Bind" of a Spektrum or Compatible Remote Receiver (aka Satellite) via Configuration GUI.
******// Bind mode will be same as declared above, if your TX is capable.
******// Ground, Power, and Signal must come from three adjacent pins.
******// By default, these are Ground=4, Power=5, Signal=6. These pins are in a row on most MultiWii shield boards. Pins can be overriden below.
******// Normally use 3.3V regulator is needed on the power pin!! If your satellite hangs during bind (blinks, but won't complete bind with a solid light), go direct 5V on all pins.
******// For Pro Mini, the connector for the Satellite that resides on the FTDI can be unplugged and moved to these three adjacent pins.
******//#define SPEK_BIND //Un-Comment for Spektrum Satellie Bind Support. Code is ~420 bytes smaller without it.
******//#define SPEK_BIND_GROUND 4
******//#define SPEK_BIND_POWER 5
******//#define SPEK_BIND_DATA 6
****/******************************* SBUS RECIVER ************************************/
******/* The following line apply only for Futaba S-Bus Receiver on MEGA boards or PROMICRO boards.
*********You*have*to*invert*the*S-Bus-Serial*Signal*e.g.*with*a*Hex-Inverter*like*IC*SN74*LS*04**/
******#define*SBUS*****PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2,AUX3,AUX4,8,9,10,11,12,13,14,15,16,17**// dsm2 orangerx
******//#define SBUS ROLL,PITCH,THROTTLE,YAW,AUX1,AUX2,AUX3,AUX4,8,9,10,11,12,13,14,15,16,17 // T14SG
******#define*RX_SERIAL_PORT*1
******#define*SBUS_MID_OFFSET*988*//SBUS Mid-Point at 1500
****/******************************* HOTT RECIVER ************************************/
****/* Graupner Hott HD */
****//#define SUMD PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2,AUX3,AUX4
**/**** RSSI ****/
****//#define RX_RSSI
****//#define RX_RSSI_PIN A3
****#define*RX_RSSI_CHAN*8***//RSSI injection on selected channel (for PPM, Olrs, SBUS, etc.) (Starts at 0)
**/**** RSSI ****/
