ich weissaktuell nicht mehr weiter und wie ich das beheben kann. Ich bekomme immer wenn ich die MWC21NanoV_0991 hochladen will diesen Fehler.
Code:
In file included from C:\Users\sr\Desktop\MWC21NanoV_0991\MWC21NanoV_0991.ino:18:0:
sketch\def.h:132:0: warning: "SOFT_PWM_3_PIN_HIGH" redefined [enabled by default]
#define SOFT_PWM_3_PIN_HIGH PORTD |= 1<<4;
sketch\def.h:68:0: note: this is the location of the previous definition
#define SOFT_PWM_3_PIN_HIGH PORTF |= 1<<7;
sketch\def.h:133:0: warning: "SOFT_PWM_3_PIN_LOW" redefined [enabled by default]
#define SOFT_PWM_3_PIN_LOW PORTD &= ~(1<<4);
sketch\def.h:69:0: note: this is the location of the previous definition
#define SOFT_PWM_3_PIN_LOW PORTF &= ~(1<<7);
sketch\def.h:134:0: warning: "SOFT_PWM_4_PIN_HIGH" redefined [enabled by default]
#define SOFT_PWM_4_PIN_HIGH PORTF |= 1<<5;
sketch\def.h:70:0: note: this is the location of the previous definition
#define SOFT_PWM_4_PIN_HIGH PORTF |= 1<<6;
sketch\def.h:135:0: warning: "SOFT_PWM_4_PIN_LOW" redefined [enabled by default]
#define SOFT_PWM_4_PIN_LOW PORTF &= ~(1<<5);
sketch\def.h:71:0: note: this is the location of the previous definition
#define SOFT_PWM_4_PIN_LOW PORTF &= ~(1<<6);
sketch\def.h:136:0: warning: "SW_PWM_P3" redefined [enabled by default]
#define SW_PWM_P3 4
sketch\def.h:72:0: note: this is the location of the previous definition
#define SW_PWM_P3 A1
sketch\def.h:137:0: warning: "SW_PWM_P4" redefined [enabled by default]
#define SW_PWM_P4 A2
sketch\def.h:73:0: note: this is the location of the previous definition
#define SW_PWM_P4 A0
C:\Users\sr\Desktop\MWC21NanoV_0991\Serial.ino: In function 'void SerialOpen(uint8_t, uint32_t)':
Serial:474: error: 'void SerialOpen(uint8_t, uint32_t)' was declared 'extern' and later 'static' [-fpermissive]
static void inline SerialOpen(uint8_t port, uint32_t baud) {
MWC21NanoV_0991:271: error: previous declaration of 'void SerialOpen(uint8_t, uint32_t)' [-fpermissive]
LEDPIN_TOGGLE;
C:\Users\sr\Desktop\MWC21NanoV_0991\Serial.ino: In function 'void SerialEnd(uint8_t)':
Serial:485: error: 'void SerialEnd(uint8_t)' was declared 'extern' and later 'static' [-fpermissive]
static void inline SerialEnd(uint8_t port) {
MWC21NanoV_0991:272: error: previous declaration of 'void SerialEnd(uint8_t)' [-fpermissive]
calibratedAccTime = currentTime + 500000;
C:\Users\sr\Desktop\MWC21NanoV_0991\Serial.ino: In function 'void store_uart_in_buf(uint8_t, uint8_t)':
Serial:491: error: 'void store_uart_in_buf(uint8_t, uint8_t)' was declared 'extern' and later 'static' [-fpermissive]
static void inline store_uart_in_buf(uint8_t data, uint8_t portnum) {
MWC21NanoV_0991:273: error: previous declaration of 'void store_uart_in_buf(uint8_t, uint8_t)' [-fpermissive]
} else {
exit status 1
