Im Prinzip ein X8R, mit der Möglichkeit einen zweiten S-Bus Empfänger anzuschließen. 35$ ohne Steuer ist ein interessanter Preis. Kombiniert mit einem XSR sollte das auch in engen Rümpfen funktionieren. Bin mal gespannt. Hier der Link zum RCG Thread
A multifunctional receiver from FrSky! RX8R, a receiver which has 8/16ch full duplex telemetry and redundancy functions!
Specifications:
• Dimension: 46.25×26.6×14.2mm (L×W×H)
• Weight: 12.1g
• Number of Channels: 16CH (1-8ch from conventional channel output, 1-16ch from SBUS port, or combine two RX8R to become a 16 channels receivers)
• With RSSI Output on Board: Analog 0-3.3V
• Operating Voltage Range: 4.0-10V
• Operating Current: 100mA@5V
• Operating Range: full range (>1.5km)
• Firmware Upgradeable
• Compatibility: FrSky radios/transmitter modules in D8/D16 mode
Features:
• Parallel two RX8R to become a 16 channel receiver
• Smart Port enabled, realizing two-way full duplex transmission
• Supports redundant transmission of two Tx modules in parallel (Sbus input: the signal from the slave receiver(Sbus receiver) for backup)
The redundancy function:
For the master and slave receivers, when the master receiver goes into failsafe, the output signal from the slave receiver will be used until the master receiver works again.
Notes:
1. When both the master and slave receivers go into failsafe, the failsafe signal from the master receiver will be output;
2. The slave receiver should be in no telemetry mode.
Specifications:
• Weight: 12.1g
Features:
Notes:
