Hello,
to assure that I am not doing any big mistakes or forgetting anything I would like to share my planned components and the way I am planning to combine those. Thanks a lot for your feedback in advance.
This is my plan for building a Tricopter designed for filming and photography with the possibility to locate filming-/phototargets via fpv.
1. Flight controller: APM 2.6 with LEA6H GPS
http://www.rcmaster.net/de-apm-2-6-ardupilot-mega-flugsteuerung-mit-6h-gps-f%C3%BCr-multicopters-flugzeuge-p235708.htm
2. Flight controller power supply: HKPilot Power Module
http://hobbyking.com/hobbyking/store/__43766__HKPilot_Power_Module_with_XT60_Connectors_and_6_Pin_150mm_Cable.html
3. Tail Servo: TGY-306G-HV
http://www.hobbyking.com/hobbyking/store/__31624__TGY_306G_HV_High_Voltage_Ultra_Fast_High_Torque_MG_Digital_Alloy_Cased_Servo_3_7kg_EU_warehouse_.html
4. Motors: Tiger MN3110-26
http://www.premium-modellbau.de/Brushless-Motoren-T-Motor-MN3110---26-470kv-Tiger-Brushless-Motor-3S-6S-80g-Quad-Hexa-Multicopter/a47082247_u2344/
5. Propeller: Turnigy 14x4.5 (2x CCW 1x CW)
http://www.hobbyking.com/hobbyking/store/__37282__Wooden_14x4_5_propeller_1pc_bag_EU_warehouse_.html
6. Motor ESC: BULL TEC 35A 4S SimonK N-FET
http://www.premium-modellbau.de/Brushless-Regler-BULL-TEC-Brushless-Regler-BULL-TEC-Multicopter-Brushless-Regler-35A--2S---4S-Lipo-3A-BEC-SimonK-N-FET/a46536159_u2344_z568dcb3d-62ed-4e2b-acbb-cbc3edbd082e/
7. Remote control: Walkera F7DS
http://www.rcmaster.net/de-walkera-devo-f7ds-fpv-sender-2-4g-bild%C3%BCbertragung-kit-version-p235720.htm
8. Receiver: Walkera RX701
9. Receiver power supply: 5V UBEC
http://www.hobbyking.com/hobbyking/store/__36305__5V_5A_UBEC_2_5S_Lipoly_7_2_21v_EU_warehouse_.html
10. Videotransmitter: Walkera TX24D-01
http://www.rcmaster.net/de-walkera-2-4g-bild%C3%BCbertragung-sender-tx24d-01-p235824.htm
11. Battery: 4S 6000mah 25C
http://www.hobbyking.com/hobbyking/store/__32643__Turnigy_nano_tech_6000mah_4S_25_50C_Lipo_Pack_EU_warehouse_.html
12. Gimbal: Tarot T2D
http://hobbyking.com/hobbyking/store/__44327__Tarot_T_2D_GoPRO_3_Brushless_Camera_Gimbal_and_ZYX22_Controller.html
13. Gimbal power supply: 12V UBEC
http://www.hobbyking.com/hobbyking/store/__18788__12V_4_5A_UBEC_2_5S_Lipoly_7_2_21V_.html
Apart from this there are other components, as Lipo adapters and breakout-cable, cloverleaf antennas, go pro camera, Low-voltage beeper, low signal beeper, etc.
The AUW will be approx. 2.1kg
Questions that have already come up are:
1. Can I connect the ESCs and the UBECs all to the same Lipo by just soldering them to bullets or however connect them to the lipo-breakout-cable?
2. What type of powersupply would I need for the Video TX? Can I connect it to an existing(planned) UBEC?
3. Does the Tail-Servo work by just attaching it to the APM2.6 board?
4. Are there any parts that could be improved/better solutions?
5. Any good onlineshops in Europe/Germany to get these parts?
6. Have I made any big mistakes?
Thank you very much for you attention and feedback in advance!
best regards
Colya
best regards
Colya
